Let me start off saying that I have searched and gotten a wealth of info from the forum to help me so far, but I want to confirm my current assumptions before I start buying parts...
I have an 86 325es that for the past month or so has had an issue with the tach reading too-low RPM (i.e. should be around 3k, displays ~2k). I assumed I had an engine speed sensor going bad (not gauge or ground- related), since my OBC was also suddenly claiming I was getting >34mpg over the past three tanks of gas. (actually closer to 26) This may or may not be related to my current problem..
Other than that, it's been running great all summer long until yesterday. Now it cranks but won't start.
The first thing i did was check that the Engine speed sensor and Reference sensor inputs at the DME- both read around 1K ohms.
My next steps are to see if I'm actually getting pulses from the speed and ref sensors, and if so, try to find a replacement DME.(anyone have an 027 for sale?)
My questions are:
1. would I still get fuel without the engine speed pulse?
2. what if I'm not getting a pulse from the flywheel? How much of a pain is that going to be to fix?
Sorry for the long post and thanks in advance.
Pat
- I confirmed that I have fuel, but no spark as per bentley test procedures.
- Checked all power and grounds to the DME as per the bentley and everything reads good
- Measurements at the coil are within spec. (primary res =.7ohms, secondary= 5.6K)
- Cam is turning so I'm ruling out timing belt.
My questions are:
Pat
