How does ac signal reach DME? is it a pin on the main connector or?
High idle, lots of diagnosis!
Also, when starting the car stone cold it idles at 750.. thats wrong. lol
When turning the key to run position I have continuity between the 2 pins on the coolant temp sensor harness. Coolant temp sensor tested good.
what is complete list of vac leak locations?Comment
My car also idles around 750 when its cold... then goes up to 1k when its warmed up... in for answers..Comment
What are other possibilities besides vacleaks???
Id be down to check for vac leaks by spraying with brake cleaner, etc. need a list of all the places though
ALSO: After reading the bentley.. I believe my coolant temp sensor is still at fault. I hard wired the connections, but I need to double check they work.
THUS, how do I know it works? Just continuity test between the two terminals of the coolant temp sensor connector. I have continuity thereLast edited by 5Toes; 08-04-2012, 08:50 PM.Comment
