My 86 eta project car has been misbehaving every time I go to work on it.
I'm blaming the inanimate object rather than myself because I'm mature.
So anywho, I'm just about ready to FINALLY piece this bitchass car back together when...
*yoink*
I twist the head off of a crank pulley bolt. Barely exerting any force. old bolts? I dunno. No big right? Just drill in, and then use an easy out. zoop!
Problem: I had used red threadlocker when installing the bolts.
After much toiling it's clear that the threads are stuck permanently.
Here is how it stands:
^^^That bolt is 100% smooth and flush right now BTW
So the question is...Has anybody installed a crank pulley with only five bolts before? Would that throw the crank out of alignment, or would it be fine so long as they're threadlocked? It's against my nature to do that, but I currently lack the resources to easily pull the crank bolt and replace the pulley mounting piece. Dafuk?
*yoink*
