1987 325 won't start! Help
  • craiggroves91
    • Oct 2009
    • 3024
    Originally posted by jlevie
    That does sound like a dead pump, but to be sure jumper the fuel pump relay socket. Bad timing reference sensors, a DME power problem, etc., could prevent power from being applied to the pumps since the DME controls the relay and only causes the pumps to run when it sees timing data from a rotating engine.
    In tank was dead. Friend loaned me a pump and we got fuel to the regulator now. But now I don't think there is spark!
    We multimetered the coil and its not getting 12v
    1989 BMW 325i SOLD
    1998 BMW Estoril Blue e36 M3/4/5 SOLD
    1987 BMW 325 (The Piece) SOLD
    1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      The coil positive post gets 12v directly from the ignition switch via C101. To produce spark the the DME grounds the coil. One must, therefore, check for power to the coil by measuring from the coil positive lead to a chassis ground. If you don't have power to the coil start tracing back to the ignition switch.
      • craiggroves91
        • Oct 2009
        • 3024
        This is just so confusing.
        How does the car go from running to not running with a dead fuel pump and no spark all of a sudden?
        1989 BMW 325i SOLD
        • craiggroves91
          • Oct 2009
          • 3024
          been working of this thread a little bit
          Where does the DME ground?
          1989 BMW 325i SOLD
          • e30trooper
            • 11576
            jump the relay. Remove the return fuel line after the fpr. If you get tons of fuel then your pumps are working some what. Also check the fuses.
            You can test the in-tank pump ( can be messy ) by removing the rear seat. Take off the cap that covers the fuel pump. The fat hose on the right side sends to the HP fuel pump. Disconnect that hose. Bump the stater ( turn key but make sure your in neutral /e brake is on ) If fuel pumps out then your in-tank pump is working.
            If that works out then jump the relay, undo the return line hose ( when you jump the relay it turns on the pumps even when the keys are out of the ign. ) no fuel then try tapping the pump under your car next to the rear driver side wheel. Hit the pump not filter.
            GL You should find out.
              A dead in-tank pump on this car won't necessarily prevent the engine from running. The high pressure pump may be able to suck fuel through the dead pump, especially when the tank is pretty full. That makes the high pressure pump have to work too hard, contributing to early failure of the pump, and starvation may occur below a 1/2 tank.
              Sudden loss of spark is going to be the result of a part failure. Most commonly those parts are the timing reference sensors, main relay, fusible link, or ignition switch. But there are other possibilities.
              • craiggroves91
                • Oct 2009
                • 3024
                Checked the fusible link.
                Im going to have to go through the other things.
                I read something about the ECU not getting power/ground if the check engine light on the instrument cluster isnt lighting up.
                Mine doesn't. Cant recall if it did before or not.
                1989 BMW 325i SOLD
                  If the CEL on the dash doesn't come on when the ignition is switched on and the CEL bulb isn't burned out, there is a problem with the DME, it's power, or it's ground.
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    How do I test power/ground?
                    1989 BMW 325i SOLD
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      I'd like some more help with this :(
                      This is so annoying.
                      1989 BMW 325i SOLD
                      • Alberthype
                        • May 2011
                        • 130
                        I would help but I don't have a car anymore and I'm taking 19Units. :) love my life
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          I need to get this thing running guys!
                          Bad timing reference sensors If we are talking about the two on the trans, I inspected them and they look good visibly. I'm not sure how to test their resistance
                          Missing Timing reference on flywheel Its there
                          Bad main relay Not sure about this. I switched it out with one I have laying around, no change. How can I test this?
                          Bad fusible link Should be good, I checked it out. It's not burnt
                          Bad DME ground Where does it ground?
                          Bad ignition switch Would this stop it from cranking? or does it stop it from getting spark also?
                          Bad DME I'm starting to think its the DME. I don't get the check engine light on the cluster
                          1989 BMW 325i SOLD
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            Bump!!! Please help!
                            1989 BMW 325i SOLD
                            • Alberthype
                              • May 2011
                              • 130
                              Any Info on this?
                              • e30trooper
                                • 11576
                                eta?
                                E's dont have CEL's btw
