325i throttle body questions
  • Bretts85E30
    • 340
    is there a place to get the fittings that tend to be loose that are for the icv and brake booster vacuum lines?
    i bought a throttle body from the jy for my i head swap conversion and i need the those fittings for it. that way i can finally do the swap.
    You'll have to get the fittings from a throttle body, or get a throttle body that has them. They aren't available as separate parts.
      • 37833
      Just silicone or JB Weld them in place. No reason for them to be removable anyway.
      Grover Beach, California
      BimmerHeads.com
        JB weld is far better than silicone, which won't last long. Clean the nipples and bores well with acetone or lacquer thinner smear with JBWeld and allow it to cure for at least 12 hours without starting the engine. Epoxy the elbows into place with the throttle body on the intake and all hoses in place to get the angles right.
        • Bretts85E30
          • 340
          K so i guess I gotta go back to the jy to find the fittings since I still need a few things from there anyway i may get lucky and find em
          • reelizmpro
            • 9553
            Go back and get the fittings.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Bretts85E30
              • 340
              I searched for them while I was there with no luck so maybe ill get lucky Tuesday when I go again
              • barry
                • 1642
                I have some fittings are you talking about the elbows?
                • Bretts85E30
                  • 340
                  Yeah all 3 the lil ones and the big one for the icv hose connection
                  • barry
                    • 1642
                    TB connectors
                    I have one small elbow and one large for the ICV $20.00 shipped
                    Thanks
                    Barry
