passenger side oil sensor thingy?
  • kickinindian
    • 2327
    what is the sensor that goes into the passenger side of the oil pan i noticed that the wire is cut on mine nothing really wrong with my car really, just noticed when putting in new motor mounts.
  • reelizmpro
    • 9533
    There is no sensor IN THE PAN except for the oil level sensor. Unless you're talking about the oil pressure switch in the block?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
      The only sensors on the passenger side of the engine are the oil pressure switch and the CPS on an M20B25. The oil pressure switch screws into the block below the oil filter and just above the oil pan.
      • kickinindian
        • 2327
        yea it screws into the block but goes into the oil pan the wires to it are severed and idk where they go or what its for, but if it is the oil pressure switch my light isint staying on and when the oil does run low it turns the check panel light on.
