Hey guys,
Trying to figure this out before I get tired of throwing money at it.
Car: 1988 M20 325i 5 speed.
Problem: If car sits at idle on a "warmish 80 degrees and up" day for longer than 5 mins, the temp needle will creep up to the 3/4 mark. If I turn on the heater, it goes down, or if I take it for a spin.
I have already replaced with new parts:
Thermostat
Fan clutch
temp sender
water temp sensor
Aux fan switch
I noticed that the aux fan will only turn on if the AC switch is turned on, will never turn on if the temp creeps up.
I think I need to replace the resistor or relay, but im not sure, and im getting tired of throwing money at the problem. Any help/tips are greatly appreciated!
Thanks R3v.
Thermostat
Fan clutch
temp sender
water temp sensor
Aux fan switch
Thanks R3v.
