E36 TPS Adapter
  • darvo
    • Dec 2010
    • 407
    E36 TPS Adapter
    Will this adapter work for my M20b25 TB, to fit an E36 Tps on it?
    The VAC Motorsports S14 TPS adapter allows install of a potentiometer type BMW TPS to provide a compatible signal for aftermarket ECUs. Our unique to VAC design greatly improves compatibility with different Engine Management and TPS as it allows you to ‘clock’ the TPS sensor for use with a wide range of setups. Our adapter may cost a bit more, but saves time and calibration problems in the long run. Includes: Hardware VAC Billet TPS adapter
  • 5Toes
    • 9836
    Probably not, the computer doesnt know how to read the new TPS's signal
    Unless you are megasquirted, etc.
    • darvo
      • Dec 2010
      • 407
      I am, I just dont know if that adapter works for me.
      Because VAC staff couldnt tell me if it worked
        • 34844
        if the bolt pattern of the S14 TPS is the same it should work. it looks the same to me.
        • darvo
          • Dec 2010
          • 407
          What about the E36 bolts?
