oil?
  • Wschnitz
    • 8089
    oil?
    Sure this question had been asked before but what oil should I use in my 325ic.
    Seattle so temps are never below zero and never above 100.
    willschnitz
  • idanity
    • Jun 2006
    • 775
    rotella...
    or castrol, mobil1, with zinc additive.
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
    • Herr Faust Schinken
      • Feb 2012
      • 3580
      15w-50 or 20w-50 is what's recommended
      88 325is Five Speed
      Lachssilber
      • Keith M
        • 2338
        Castrol GTX 20-50.
        • Wschnitz
          • 8089
          I am hearing allot of castrol gtx non synthetic 20-50. What about filters? Id like a MANN but they don't sell at AutoZone.
          willschnitz
            • Feb 2012
            • 3580
            Pelican parts there like 4 bucks I normally buy two or three at a time
            88 325is Five Speed
            Lachssilber
              This, and use a non-synthetic with a high ZDDP level. I use Brad Penn, but Valvoline VR1 is easier to find. Rotella used to be a good choice but I'm told it now has more "modern" ZDDP levels.
              As for filters, use the BMW part or a Mobil 1 filter.
              • idanity
                • Jun 2006
                • 775
                mann or Mahle are oem filters from azautohauz .. i buy 10 at a time....4.25 each...don't forget the crush washer.
                rotella is used by many a turbo owner...but yeah...keep your zinc levels high...i havent heard of any 'new'' formula, gonna have to look into this...and ii always add a bottle with every oil change..and i change the oil twice as much as recomended...bc i live i higher rpms...
                torco zinc..
                if you are an economy driver, just regular maintenence is fine.
                3 pedal club
                200,k+ club
                cabrio club
                </div>
                linux since 1999
                  • 37833
                  I use ONLY Valvoline VR1 20w50.
                  Grover Beach, California
                  BimmerHeads.com
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    For those of you in California, high ZPPD level in your oil will eventually kill your cat and you will have problem passing smog so keep this in mind.
                    • M-technik-3
                      • 18946
                      They were made to span a lifetime, all OEM for most part older than 20 years so Using a high Zinc content to keep engine wear at bay is better than an engine swap for most.
                      States like California need to consider relaxing standards on vehicles as they get older. A engine with 200K miles is not going to run like one with 5K miles.
                        • 34844
                        this is nonsense. a stock E30 cat is very high quality and will basically last forever.
                          True, provided that the engine doesn't run rich and isn't burning oil. Excess hydrocarbons in the exhaust can overheat and damage the matrix.
                          I've heard two reasons for lower levels of ZDDP. The most popular is that it was done to extend the life of the catalytic converters. The other reason, which I find more plausible, is that reducing ZDDP makes it easier and cheaper to recycle engine oil.
                          • dnguyen1963
                            • Nov 2011
                            • 2651
                            Why is this nonsense? Zinc will complex with palladium/rhodium and, in effect, inactivate the metals. If your car is burning oil with high level of ZPPD then your cat will be destroyed in no time. This problem is not detrimental to properly tuned car; however, every car will burn some amount of oil. For a 20+ yrs old car, you might be able to pass emission in 49 states, but could be a problem for California drivers.
                            • idanity
                              • Jun 2006
                              • 775
                              its nonsense b/c newer cats are cheaper and crappier...and teh U.S. govt made a law or something to force the warranty that all NEW cats are garunteed to last 120k or something...don't quote me on specifics, but thats what i read...somewhere, sometime..maybe in the deep web...the car manufactures and oil companies just came together to help each other out...and possibly the new metals in engines don't need zinc...i didn't read that last part, but its plausible.
                              3 pedal club
                              200,k+ club
                              cabrio club
                              </div>
                              linux since 1999
