slight hesitation
  • Afredo
    • 349
    slight hesitation
    89 325i, 118k on it, have a slight hesitation during acceleration from about 2-3k rpm, and sometimes when you initially depress the throttle it'll bog down until you give it more gas. just replaced the fuel tank/all fuels lines leading to tank/fuel filter, problem still exists. there's a whining sound when its running leading me to believe there's a vacuum leak, the main intake tube has some cracking/dry rot so I'm going to replace that as well as the secondary smaller tube. If that doesn't fix the hesitation/bogging, any thoughts on what it could be?
    "Once more into the fray."
  • blocke
    • 1305
    Afm out of adjustment, and likely intake leaks
    Parts Wanted
    The Never-ending Resto Mod
    • dnguyen1963
      • Nov 2011
      • 2649
      You have already identified the problem! Vacuum leaks.
      • Afredo
        • 349
        Afm?
        • blocke
          • 1305
          The big metal box on your intake. It's a barn-door style, POS.
          Search on here, there are several threads about how to clean and adjust it. But fix the intake leaks first. Having a shop run a smoke test is the only for sure way to find them all.
          Parts Wanted
          • fronton
            • Oct 2009
            • 1262
            sounds like an autotragic
            • Afredo
              • 349
              autotragic?
              • dnguyen1963
                • Nov 2011
                • 2649
                Originally posted by Afredo
                autotragic?
                AFM = Air Flow Meter.
                Autotragic - R3vlimited hates E30 with automatic transmission.
                • Afredo
                  • 349
                  I most certainly do NOT drive an automatic, you insult my honor sir!
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    Not me...just give you the definition.
                    • fronton
                      • Oct 2009
                      • 1262
                      ha, whew. I had an autotragic at one time in my life and your symptoms line up with what I had to accept as a user of said transmission.
                      • Afredo
                        • 349
                        found a vacuum leak coming from the rocker plugs on the side nearest the firewall. also, the iac motor seems to be running even when the motor is off but key is on, not sure if its supposed to do that. one other vacuum leak coming from the other side of the valve cover near the front of the motor can't tell if its actually coming from the valve cover or not. replaced main intake tube and cleaned maf sensor, still hesitating and bogging down when throttle is initially depressed quickly. thoughts?
                        • dnguyen1963
                          • Nov 2011
                          • 2649
                          Did you repair the leaks from the valve cover?
                          • Afredo
                            • 349
                            not yet, but would that really have much to do with it? its not part of the intake system really.
                            • dnguyen1963
                              • Nov 2011
                              • 2649
                              Leaks in valve cover can affect your idle big time.
