slight hesitation
  • Afredo
    • 349
    Originally posted by dnguyen1963
    Leaks in valve cover can affect your idle big time.
    idle isn't the problem, my idle is fine. the issues are if i hit the throttle quickly, it bogs down and then catches back up again quickly, sometimes it'll cause me to stall out if i'm pulling away from a light or something. and also there's a slight hesitation in acceleration between 2 and 3k RPM.
    "Once more into the fray."
    • dnguyen1963
      • Nov 2011
      • 2651
      If you think about it, when revving an engine you can create quite a bit of suction; therefore, any vacuum leaks would cause the engine to bog down and stall. Rule # 1 - find any vacuum leak and fix it right away before you do anything else. If you follow this rule you will save yourself much headache.
