Will 325e plug wires work on an is motor?
  • GrimmSpeed
    • 52
    Will 325e plug wires work on an is motor? If not, what kind of symptoms would you get if you tried to use them?
    Thank you,
    Mike
    • 34844
    they will work but the eta wires are missing the impulse sensor on #6 which helps the i computer phase the injector pulses with the engine cycle. a slightly rougher idle and less efficiency is the result.
    if you're in a pinch it's not a big deal but eventually you'd want the proper wires. I really like the Bremi aftermarket wires, inexpensive and great quality.
    • GrimmSpeed
      • 52
      Ok thank you, this is kinda the last thing i was curious about in my no start car. Time to get on with the tear down so i can rebuild and rewire the engine.
      Mike
