early icv to late icv wiring
  • Bretts85E30
    • 340
    ok im looking as a temp solution when i swap in my I head/intake/throttle body to wiring in the late model icv with the harness i got from another harness when i got the icv from the jy.
    my question is would i be able to wire it up even as a 3 wire or is it a lost cause.
    the wires i have coming from the harness i chopped from the jy with the icv i got are all solid red/center, blue/right, black/left
    what wire does what and could i mock it up to work.
    thanks for the help
  • Kvasi
    • Apr 2011
    • 1122
    You cant mix icvs with 2 and 3 pins if thats the question.
    • Bretts85E30
      • 340
      damn im gonna have to figure out how to make mine work til i swap harnesses then.
      • reelizmpro
        • 9543
        Not even sure what r are asking...
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • Bretts85E30
          • 340
          the problem im coming across is using my icv with the new style intake boot and icv setup thats near the airbox instead of near the cold start injector im trying to make it be as complete as possible before i get the last couple things i need for the harness swap.
          im doing the head swap next weekend then come the next 50% off weekend im gettin the last couple things i need from the jy but in the mean time i wanted to retrofit the late model "L" style icv into my 2 wire stock one but im fine with just using my original boot and icv til i can get the last bits of the harness swap collected.
            • 37832
            Just wait until you have the correct engine harness.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
              You can't use the late model ICV with the M20B27 engine management system. And I don't think you can use the M20B25 injectors either. Wait until you have all the parts for the conversion.
              • Bretts85E30
                • 340
                the injectors i knew about cuz of being high impedence just the icv i didnt know
