fan clutch test
  • brutus87
    • 6280
    fan clutch test
    Hey there.
    I searched and searched for a fan clutch test and several threads had different information, sometimes opposite.
    I saw that one can do the newspaper test. how does that go again? My fan is super easy to stop when the car is fully warmed up, but slightly harder when dead cold. Is that a sign that it is good or bad?
    Replaced the fan clutch just a year ago with one from Blunttech.
    Car: 1988 325is 5 speed
    Thanks!
  • limp mode
    • Jun 2012
    • 117
    i think that means its bad.. im also interested in this answer
    • dnguyen1963
      • Nov 2011
      • 2651
      It's dead...only a year old? Blunttech normally sells decent stuff.
      • TurboJake
        • 3780
        They normally are harder when cold. That's good.
        They should be even harder to stop when hot. That's what yours should be.
        Being able to stop it easier when warm means it's bad.
        Leave Me Transaction Feedback
        • sayed ali
          • 762
          ^ +1
          M20B28 Turbo
          My Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=255839
          • bmwguy325is
            • May 2011
            • 1263
            As for the newspaper test. You roll up some news paper and stuff it in the fan while its going. If it chews up the paper its good. If it stops the fan its bad. Mind you you have to do this hot. And Im not a fan of shoving things in a fan. Well unless its a huge fan and its a sack of kittens LOL
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • brutus87
              • 6280
              Thanks everyone for the help!
              Its so weak when the engine is warm that I can stop it with my finger(I did the newspaper test first and it stopped instantly).
              New radiator, thermostat, hoses, and clutch fan tomorrow, yay.
              • cabriodster87
                • Jan 2011
                • 1042
                After sitting in traffic, i can hear mine move air pretty loudly, especially going through the gears.
                Reich und Roll!
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  All the ones Ive bought (maybe 8 or so) have been either Sachs or Behr and I'm quite sure thats what Blunt sells. They also ALL are labeled "this side up" so they should not be laid on their side. I suspect this has to do with it being a fluid clutch and since its guaranteed that they traveled upside down and sideways I try to stand them up from the moment they arrive til I install them.
                  I'm not sure what the significance of all this is, but it could be a factor in life expectancy...and the only time they serve ANY purpose in a healthy cooling system is at idle when there is no natural air flow.
                  Alice the Time Capsule
                  • brutus87
                    • 6280
                    Replaced the thermostat with an 80 degree one, new radiator, hoses, and fan clutch, bled properly,car runs AWESOME now.
                    The fan clutch is much stronger and I can hear it when I take off now. The "new" one from a year ago was bad.
                    I let it idle in the heat for 40 minutes, didn't move at all from 1/2 mark.
                    Did the same test with the AC on, same thing.
                    Car is golden.
                    Very happy E30, means I'm happy too.
                    Thank you everyone for your help, you make this community great!
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      F3AR, is that you?
                      2014 Alpine White 335i MSport
                      (Daily Driver)
                      Full Mperformance Aero
                      KW V2 Coilovers
                      VRSF Catless Downpipes
