rough running m20
  • Ceeker
    • Sep 2009
    • 2821
    rough running m20
    So I changed all my intake gaskets, vacuum lines, upgraded to 17lb rebuilt injectors, replaced the wires for the Bavauto's and necessary gaskets.
    All the plugs are firing but the motor has a rough idle. I removed the plugs and found #1 cyl plug wet. checked to make sure I was getting spark and it does.
    what could be the problem?
    any help would be appreciated.
    thx.
  • dnguyen1963
    • Nov 2011
    • 2651
    Check the o-ring on the #1 injector...sometimes they do not seat right.
    • Ceeker
      • Sep 2009
      • 2821
      thanks..will do..I was thinking of removing that one just to see..much appreciated.
        1) Replace the O2 sensor if it has 100k on it or is of unknown age.
        2) Put a professionally rebuilt set of OE injectors back in.
        3) Have a smoke test run and fix the leaks it reveals.
        There are other possibilities, but start there.
        • stamar
          • Apr 2011
          • 1362
          I think you can save some money by switching injector 1 with 6 and see if the problem follows it.
          • Ceeker
            • Sep 2009
            • 2821
            I was going to go that route. thx for the advice. we'll see what happens today. :-) I don't think it is necessary to do all that work when I know the car very well.
            • Ceeker
              • Sep 2009
              • 2821
              turned out the M50 injector intake o-rings are a smiggin smaller then the M20's. I bought them rebuilt from here but I guess it wasn't taken into consideration they needed to put the M20's rings on instead for a swap. I tested this by reinstalling my M20's and car works fine. Also noted that the m50 injectors went into the intake a bit easier then the M20's.
              -Vacuum leak at the seal rings.
              thanks for everyone's input. - much appreciated.
              Ernie
              • dnguyen1963
                • Nov 2011
                • 2651
                Glad you solved the problem!
