Overheating
  • EuroTrash///E30
    • 128
    Overheating
    I just replaced my entire cooling system, new water pump, radiator, thermostat, fan and fan clutch, hoses and put new belts on it, but it still runs hot when i drive it. It cools down when it idles. I checked the oil for water and it was fine and made sure my belts were tight. Anyone have any suggestions on what it could be?
  • Swanny
    • Mar 2012
    • 2834
    Burped the system yet?
    Swanny!
    SUCKERS.
    • EuroTrash///E30
      • 128
      Yeah, already did that too
      • Swanny
        • Mar 2012
        • 2834
        Mine was just acting a fool the other day....somehow got an air lock somewhere so i ran it with the heat on, and kept playing with having the cap on/off and adding fluid till it stopped accepting any more. Haven't had a problem in over a month now.
        So I guess my question is did you have the heater on wheb you burped?
        Swanny!
        SUCKERS.
        • EuroTrash///E30
          • 128
          no, the heater was off when i burped it
          • stamar
            • Apr 2011
            • 1362
            actually air in the system will usually overheat when idling and go down when at freeway speeds.( if its a small enough bubble)
            does the heater blow cold?
            • EuroTrash///E30
              • 128
              No, the heater blows hot
              • EuroTrash///E30
                • 128
                No ideas?
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  Bleed your system again with the heater on Max. Take out the tstat and drill a small hole on top to facilitate air removal.
                  • Cletonius
                    • 2809
                    Don't drill holes. Jack the front up about an inch, helps a lot
                    - Josh
                    1990 325is
                    Need a shift boot?
                    Looking to buy shift boot frames, PM if you have one to sell
                    Here's what happens when you let the internet pick your license plate
                    • Kvasi
                      • Apr 2011
                      • 1122
                      Park in a steep uphill and let it idle and bleed it, should do the trick. If not do the same and keep it steady at about 2k rpm.
                      • Swanny
                        • Mar 2012
                        • 2834
                        Yup
                        Swanny!
                        SUCKERS.
                        • Ceeker
                          • Sep 2009
                          • 2821
                          drilling the hole won't matter either way. it can help with releasing trapped air but won't affect the operating temp of the car. put the car on a slight incline about 20 degrees. run the motor with the heat on full. top up the coolant, get the car hot -crack the bleeder open and as mentioned get the revs up to 2k or so. you will see steam and some gurgling coming out. Run it till you see a stream of coolant coming out. close the bleeder and watch the temp gauge. Then take it for a spin if it is still doing it - repeat the process until temp stabilizes.
                          question: by chance are you running the a/c while driving? if you aux fan isn't working the temp will increase with the extra load on the engine. that's if you have or use a/c. often the aux fan resistor packs it in and although the a/c works your engine temp will rise.
                          • stamar
                            • Apr 2011
                            • 1362
                            bleed it from the overflow hose near the radiator cap. dont drill a new hole unless you have a new screw to put in it, what you just did was creat another leak.
                            • dnguyen1963
                              • Nov 2011
                              • 2648
                              ??? How can a small hole in the tstat create another leak? Trust me, this helps bleeding the system very well. Even parking the car or jacking it up can still have air trapped in the tstat housing. Keep in mind that, in colder climate, small hole in the tstat will require a bit longer for the engine to get up to operational temp.
