milling the flywheel, need rebalancing ?
  • chris_rai
    • Sep 2009
    • 99
    Hi there
    My stock m20 flywheel has been milled on a lathe ( the rear lip ), weight comes down 7.3kg. ( from 8.4 kg )
    does it need rebalancing ?
    thanks
  • reelizmpro
    • 9559
    yes
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • F34R
      sLaughter
      • 12376
      Yes it does, with removing the rear you cannot get it perfect for rotational balance. You could end up with a huge issue on your hands. I have had my Uncle reduced both of my M20 flywheels to 13lbs and then sent them off for balancing.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
