M50 injectors, Engine oil light?
  • Pocket Chant
    • Mar 2012
    • 403
    So, I just swapped my standard M20 injectors to M50 17.5# ones. Stomp test told me it was running rich, which I'm 99% sure is due to the chip. However, the check panel also turned the engine oil light on. I checked it, the dipstick shows it as fine, and it ran fine. Any insight?
    1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
    MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
    Originally posted by MclubSport
    Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
    Horrible with responding to PMs, I'm so sorry.
  • Pocket Chant
    • Mar 2012
    • 403
    Bump, any help?
      • 37829
      The engine oil light has nothing to do with the injectors.
      Your level sender is probably going bad.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • BMW_325i
        • 61
        Must just be coincidence. Is it possible you disturbed the oil level wiring while changing the injectors?
        1988 Lachssilber E30 325i sedan.
        Factory fit-out: manual; SILBER LEDER; M SPORT SUSPENSION.
        Modifications so far: Miller MAF + 19# ECU; Ford 19# Design 3 injectors; IE adjustable FPR; KAMotors CF airbox; IM MTX-L; EBC Greenstuff.
        Retired - '83 Arctic Blue E28 528i powered by M30B32
