30lb injectors in m20 e30
  • txbeemertx
    • Mar 2012
    • 27
    I want to change the injectors, just passed inspection and emissions, but sputters periodically . I'm also going to change cap and rotor. Plugs already changed. Was wondering if I can go with 30lb ?
    If so any fuel tweaking? Thanks guys!
  • 5Toes
    • 9836
    m50 injectors are the biggest you can go on a stock engine.
    they are 17.5lb/hour
    I have some for sale. $40 shipped
    • txbeemertx
      • Mar 2012
      • 27
      What cOndition are the injectors?
      • ForcedFirebird
        • Feb 2007
        • 8300
        Your stock injectors are good for at least 175whp. No need to go larger, specially if you don't have a matching chip.
        john@m20guru.com
        Links:
        • txbeemertx
          • Mar 2012
          • 27
          Been reading up a little. Stock is 14lbs and I guess m50 is 17.5
          So I see the car can handle 17.5lbs, with out tweaking, so it's just preference?
          • MaksV
            • 1042
            You can easily run 17.5# M50 injectors with no issue on a Stock M20. If you have a chip and some bolt ons you can go to 19#. I sell both. You can look in my thread for what you need.
            Maksim
            CHEAP REBUILT INJECTORS
            Need Quality Brakes? BimmerBrakes has it!
            For anything Else go with BluntTech!
              • 37829
              The car won't even run with 30lb injectors on a stock computer.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • sayed ali
                • 762
                Originally posted by forcedfirebird
                your stock injectors are good for at least 175whp. No need to go larger, specially if you don't have a matching chip.
                +1
                M20B28 Turbo
                My Build Thread
                http://www.r3vlimited.com/board/showthread.php?t=255839
