my preasure light flickering on?
  • timninja
    • Feb 2011
    • 302
    driving to the store the other day and my oil pressure light started flickering at 4k,so I stopped,checked my oil it was 1/2 a qrt low filled it back to level with 5w-40 and and now it ls always on or off,temp doesn't seem to change these issues.how should go about troubleshooting this?
    The first step would be to find out what the oil pressure really is after changing the filter. That is done by temporarily replacing pressure switch with gauge.
    • timninja
      • Feb 2011
      • 302
      Where is the pressure switch?
      • camip
        • Nov 2011
        • 1253
        This happened to me check if the wire is off the switch before getting a pressure tester etc.
        • timninja
          • Feb 2011
          • 302
          wait is it a vacume hose to a solenoid switch down under my alternator in/on the oil pan?
          • timninja
            • Feb 2011
            • 302
            wait its the only sensor in the oil pan,then it is nvm,stupid question answered,btw jlevie I wanted to thank you,you've helped me repair just about every issue ive had with my e30 so far.
            • SmokeE30
              • 1730
              oil presure sensor is on the passenger side of the block single wire sensor down below the oil filter area, not on the pan itself, thats the oil level sender
              Shawn @ Bimmerbuddies
              Bimmerbuddies LLC
              717-388-1256
              2971a Roundtop Rd, Middletown PA 17057
              bimmerbuddiesllc@gmail.com
              • timninja
                • Feb 2011
                • 302
                Wait,I thought that was for the upper check oil level light?
                In that case,i have mine wire nutted off because the wire broke and exposed.
                Hmm,thanks smoke!
                • SmokeE30
                  • 1730
                  yea the level sender for the check light is on the pan itself
                  Bimmerbuddies LLC
                  717-388-1256
                  • timninja
                    • Feb 2011
                    • 302
                    Yeah I recently rebuilt my injectors and while doing that i broke that wire again and it was grounding on my intake,thanks man!
