So hers where I'm going to start so I rebuilt my m20 dropped it in
And as I was going to do a test fire I realized I wasn't getting any feul pressure so first thing I did is I went through all the fuses all the fuses were fine
Soo then I went to checking to fuel pump relay checked the relay it was fine , so then I went to the back seat and put a test light on the feul pump harness and I wasn't getting any power so then I went back to the relays ( took the covers of the relays to see if they were engageing they were so I told my uncle to put the caps back on the relays so then I decided I'd run down the fuse box with the test light to find out I had a blown fuse on #11 do I switch it out then I go ba k to the fuel pump harness to find out I'm now getting power (hmmm so then I touch the fuel pump relay and relize it was warm didn't think to much of it I went to try and crank it , then all of a sudden fuse #11 melts And I run disconnect the battery so then my uncle relizes he put the cap on back words on the feul pump relay causing the contact point to be connecting sending a constant power to my feul pump
So I took the feul pump out and the wires and the whole pump was just fucked so then I go back to the fuse that melted and ran a test light on it
It lit up , meaning the terminal was still working after cleaning up the plastic melty debris I slap a fuse in there and after I did that I had power to the feul pump harness so then I put a new feul pump on and I was getting power to the feul pump and feul pressure no blockages nothing like that
So then I went to check if I was getting spark , was getting spark ,have a new maf ,
So I know all this is going on fuel pressure ,spark ,cps and new maf
So now all it comes down to was the injectors so then after thinking if I was getting ground to the injectors I called my friend asking where the fuel inject ground was he says its in the fuse box I run it down again and find out melty terminal fuse #11 isn't lighting up
Pull fuse (not broken ???? ) I go back to the feul pump harness and all if a sudden no power so then I try cleaning the terminals and still absolutely no power from fuse 11 I take every fuse out and crack open the fuse box to make sure I had no melted wires / there was none
So no I'm stumped on what to check next
I also got the car to start with starting fluid do I'm figuring it's not the ecu
So I haven't had a chance to check the one last thing it could be wich is the fuseable link
But I was reading that there won't be any power to the ecu ir any spark if the fuseable link is bad I don't know if this is true but I basically have no idea where to start now
Soo Anything can help me
Let me know what I should do
