Later eta parts that can be used in an i build?
  • TobyB
    • 5288
    Okay, before I just throw this (mostly dead all day) engine out-
    can the block be used with the i guts (crank, rods, pistons, head) to build an i motor, or is there something
    that's different between the 2 castings that'll 'nad me?
    Thanks,
    t
    • 37833
    A lot of people will use the complete Eta bottom end (crank/pistons/rods) with i everything else. It gives you a 2.7i engine but it's a bit lower in compression than a stock i engine would be.
    Grover Beach, California
    BimmerHeads.com
      The M20B27 & M20B25 blocks are the same.
      • TobyB
        • 5288
        Thanks, Jim- that's what I was wondering.
        t
        • Keith M
          • 2338
          Just for a second I thought you were going to try a sneak a 2.7 stroker into pro3. :D
          See you at the enduro Toby.
