17lb injectors with Mark D chip
  • Tismael711
    • 791
    I purchased a new Mark D chip, added 17lb injectors and now my car, an 88 vert, appears to be getting too much gas and floods out after driving a short distance. Could i have gotten bad injectors? It appears the car is getting too much gas as i can smell gas in the exhaust. Any advice?
  • Bullet Ride
    • Dec 2010
    • 598
    It sounds like you could have an injector stuck open. However, was it a MarkD chip meant for larger injectors? If not the stock injectors should work fine.
    • dnguyen1963
      • Nov 2011
      • 2651
      If you use 17# injectors you should stay with stock chip. Aftermarket chips are designed for specific injectors. I believe MarkD is designed for 19# injectors.
      • Bullet Ride
        • Dec 2010
        • 598
        He has a chip for 19# injectors, but you have to specify it to him when buying it. He has chips for stock injectors too.
        • Tismael711
          • 791
          It might be a stuck injector cause the Mark D chip is for 17lb injectors with 91 octane gas.If i go back to 14lb injectors will i get any benefits from the chip?
          • sayed ali
            • 762
            Since the chip is designed for bigger injectors either 17lb or 19lb, so the stock injectors may not do the job properly... if you have a stock motor then there is no benefit to have 19lb injectors unless you have a stroker/turbo motor ..
            M20B28 Turbo
            My Build Thread
            http://www.r3vlimited.com/board/showthread.php?t=255839
              Originally posted by sayed ali
              S\if you have a stock motor then there is no benefit to have 19lb injectors unless you have a stroker/turbo motor ..
              Or, to 17lb injectors on a stock motor.
              • rodpaine
                • 33
                In my 1983 528e, I've been running A Mark D'Sylva E.A.T. performance chip, product# E30-027.5K5 in a used "027" DME/ECU, since 2004, which I documented here. It produces 122.3 RWHP, which is 15.8 RWHP over the stock chip in the old "008" DME/ECU, as tested on a Dyno Dynamics at York Automotive, Mt. Airy, MD. This is with the stock BOSCH 0-280-150-126 injectors and the 2.5 BAR 16.6 lbs/hr flow rate. With a 3 bar fuel pressure regulator, these injectors will deliver 18.27 lbs/hr. I am in the process of installing an MM modified cylinder head, discussed here and involves a custom chip from Mark to work with this head configuration, which involves a special cam, bee hive valve springs and several other changes. I am hoping to see somewhere between 148-165 RWHP (41.5-58.5 RWHP gain over stock), once everything is in place and fully sorted. With the exception of perhaps changing the FPR to a 3 bar regulator, there will be no change in the fuel injectors.
                FWIW,
                -Rod
                Rod's 528e support web site
                A car can be restored many times. It is original only once.
