Head gasket question.
  • e30Rooster
    • Jan 2010
    • 958
    How likely is it that oil will leak from a hg to the exhaust side of the block and not end up in the coolant?
    Sent from my C771 using Tapatalk 2
    That is entirely possible. The oil feed passage is roughly in the center of the block near the exhaust edge.
    • e30Rooster
      • Jan 2010
      • 958
      I was driving home from work and I watched my temp hit red, so I pulled off let it cool down and drove home. The fan clutch stopped grabbing and I noticed the oil leak. How much would heat affect the head gasket. It was sitting for about 9 months before I swapped it in.
      So should I check the torque on the head bolts and see if that helps or just park it till I'm ready?
        • 37829
        Doubtful that your exterior oil leak is related to the car heating up. M20 headgaskets leaking oil externally is fairly common. Next time turn the car off BEFORE it hits the red and have it towed home.
        Also, the head bolts are designed to be torqued one time only. Do not re-torque them.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • e30Rooster
          • Jan 2010
          • 958
          Now I have an excuse to get one of your heads and some headers.
            • 37829
            Not something I can argue with. ;)
            Grover Beach, CA
            www.BimmerHeads.com
