Rust stained/yellowed coolant reservoir - Can it be cleaned?
  • element6
    • Dec 2010
    • 449
    I'm tearing everything down at the moment and looking at what I should and shouldn't replace.
    My entire coolant system was full of rust from the last dumbass owner never replacing fluids. Sidenote: you wouldn't believe how terrible the green coolant smelled when I pulled all of my cooling hoses off.. not to mention it was dark orange.
    So the inside of my coolant reservoir has a rusty red coating and the outside is kind of yellowed. I tried cleaning with degreaser (formula 99 or purple power) and gasoline.. no dice. The rust layer remains, if I could just get a brush in there I could get it off.
    Any way to clean it or should I toss it?
  • fronton
    • Oct 2009
    • 1262
    toss. $80 for a new one, does wonders for an engine bay.
    • dnguyen1963
      • Nov 2011
      • 2651
      Try some rust removal products from Home Depot. But, unless you can get your hand on some nitric acid, it would be hard to completely remove the rust color.
      • element6
        • Dec 2010
        • 449
        That's why I was asking.. $80 is quite a bit for a little plastic container.
        I forgot I had some evaporust on the shelf. I'll give that a try and then some brake fluid and see what happens.
        • dnguyen1963
          • Nov 2011
          • 2651
          With all the elements, why C 12?
          • nrubenstein
            • 3148
            Quit applying chemicals to fragile plastic. It's probably already weakened quite a bit. If you *insist* on not replacing it, then paint it black.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • element6
              • Dec 2010
              • 449
              It's going to get thrown in the trash in 6 months anyways when I strip the shell down.. It's 1/8" thick ABS plastic.. what's it going to do? Crack?
              • AndrewBird
                The Mad Scientist
                • 11898
                Nothing you do to it will make it white again. It yellows due to the plastic chemically changing as it gets older. This means that the yellow is not a coating, but goes thought the plastic. The plastic it self has turned yellow. You can get it clean, but it will still be yellow.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Doesnt anyone price shop ? You can buy an early reservoir for $56 shipped
                  Alice the Time Capsule
                  • M-technik-3
                    • 18946
                    When you ask a question and a og on site say don't bother...then I hate to say it there is a reason. CRL rust remover will remove the rust but won't make it clear again. It yellows with age.
                    Take our suggestions with a grain of salt but remember most of the questions have been asked more than dozens of times in the 18 years of internet time.
                    Some of us are old hats.
                    • element6
                      • Dec 2010
                      • 449
                      That's why I asked! :p
                      I didn't go into details on my situation because I figured someone out there had tried cleaning one out before, but I searched for about 10 minutes and came up empty handed. I just asked the question because I hadn't tried anything except some degreaser and water on the reservoir.
                      I'm more interested in getting the little rust particles out.
                      Like I said.. I am just giving the motor a light rebuild for now. I want to have some fun with the e30 on the weekends.. and then it is getting stripped so I can put it away before I buy a house in about 8 months. I bought the car planning to do an S52 swap but most of us know; you don't buy the car without a place to put it and work on it.
                      Thanks for the replies.
                      • M-technik-3
                        • 18946
                        Buy the house first....Don't get stuck with rebuilding from inside out either if you can. I have been rebuilding mine for two years.
