Looking at an 88 528e... looks fantastic... how do I get it to be a 2.7i? I know SuperEta to i swaps are much easier.
SuperEta to 2.7i?
Tags: None
Swap in an an M20B25 head (or rework the head on the car with M20B25 parts), intake, throttle body, AFM, engine harness, and DME. It is really just about like turning an M20B27 into a 2.7i, but the result has slightly higher compression.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
how different are the heads? I thought they were the same heads as the 325i but with eta cams, valvesprings, lifters and rocker arms?
I know the intake manifold is different and the TB and AFM.
Do I need the engine harness? I thought I could just swap ECUs.Comment
You also can use the throttle body but it is 2.5in vs 2.7in I. It works fine just kills a bit of top end.
Oh yeah. Forgot no lifters in these.
So the simplest way to do it would be doing a cam and valve spring swap. Intake manifold with throttle and afm. And then finding a 173 ecu?
Any fueling differences?
Would the 173 ecu work in an e28?Comment
173 should drop right in. Fueling differences are negligible if any, not even sure they're different injectors.
Simplest way gets to be a matter of opinion for the head/cam. Pulling out a cam and valve springs with the head still attached is way more of a PITA than with the head pulled IMHO. It can be done though.
Because the i has slightly larger valves than the eta and it's easier than an in car cam swap, a recently freshened i head swap gets my vote for this job. Also gives you a chance to blow a few hundred extra on things that probably don't (but might) need attention like head gasket, timing belt, rusty exhaust studs, etc.:curse:sigpicComment
find a head with intake,tb and injectors with fpr. You will need the b25 afm and also a 173dme. DONE
go m30.1989 325i SETA stroker [delphin] R3V'd 8/31/2011
1989 325ix [zinnoberrot] $OLD
1970 2002 [Nevada]
Originally posted by Herr Faust Schinkenguy must have slid into something that doesn't look like a car vs car hitOriginally posted by ak-Must of slid into RobComment
