head to tdc?
  • ahalfacre5
    • Aug 2012
    • 156
    head to tdc?
    Can any one tell me how to reset my engine timing. I fucked the timing and head gasket when my rocker arms broke and I need to know how to get the timing back when I replace the head gasket. Thanks in advance
    1986 325es
  • paperplane94
    • Jul 2011
    • 420
    Must see, two thumbs up:
    cam sprockets may vary...
    • ahalfacre5
      • Aug 2012
      • 156
      Thank you thank you thank you you made my life 100x easier
      1986 325es
      • carfantiti
        • 790
        timing marks when did my super eta stroker same as video .Old school way is you can pull number one spark plug put penis in the whole with remote crank or a friend have them crank car when the air pushes out or piston hits your dick its top dead center.
        http://www.pelicanparts.com/bmw/tech...iming-Belt.htm
        you need to start learning how to search internet buddy!
        • rodpaine
          • 33
          Originally posted by carfantiti
          This is a good effort by pelicanparts, but it doesn't show or say anything about the valve cover blind plugs under the valve cover gasket. These four rubber plugs (two at the front of the head at two at the rear) become hard and brittle and can cause vacuum leaks, as well as small oil leaks on to the timing belt. These things are all too often overlooked! Replace them while doing the belt change.
          -Rod
          Rod's 528e support web site
          A car can be restored many times. It is original only once.
          • clarkson
            • 231
            I love my e30 but I don't know if I would stick my Dick in it, especially while a friend is watching....
            Pulling my hair out with all these friggin BMW's:
            2000 M5 Winter beater
            1984 318i Coupe 2.5 S14 going in the car below.
            1988 M3 Lachssilber: I'm the second owner, currently recommissioning.
            • carfantiti
              • 790
              lol
              • jeffnhiscars
                • Jun 2011
                • 6011
                Sounds like if no one was watching you might just go for it
                Alice the Time Capsule
                • dougie30
                  • Apr 2012
                  • 1708
                  Bump for I hope I didn't fuck my engine
                  So I took my head off to do the gasket, and I was cleaning the carbon off the pistons and turned the crank over a few times to access each piston.
                  So when I put my head back on all I have to do is set both head and block to top dead center right?
                  I'm asking because someone told me that now I cranked the block over a few time I need to re adjust all my valves and set my timing to the distributer and all this shit.
                  I thought you just set both to tdc, tighten bolts, and put on timing belt? Right?
                  M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
                    Turn the engine until the mark on the crank hub lines up with the notch in the lower timing cover. Next turn the cam until the cam sprocket mark is lined up with the mark on the head. Then put head on the engine and install the timing belt. Then engine/head is now in time.
                    When installing the head, make sure that both dowel pins are in place.
                    • dnguyen1963
                      • Nov 2011
                      • 2649
                      Any of you remember chemistry lab?
