Fuel pump went out so I bought a Walbro 255 good choice?
  • e30m20TurbO7
    • 1203
    Bought a 100$ dollar pump was it a good choice does it at all help you with performance , or just waste my money and mpg?
    As long as the pump has enough capacity, but not too much, it will have no affect of performance or mileage.
    • dnguyen1963
      • Nov 2011
      • 2651
      I bought Tre performance pump for $65. Works great...should not affect your mpg. Engine performance affects mpg.
      • blasphemy101
        • Apr 2012
        • 170
        Out of curiosity, how could a pump have "too much" capacity? Isn't that what the FPR is for?
        The Great Big M20 Timing Belt DIY
        Some good information I've found online (no affiliation):
        Turbo Tech (Garrett)
        Four-cycle information and cam properties for beginners (ISKY Racing Cams)
        • ApexMotorsports
          • May 2011
          • 18
          If your pump is to big in flow rate it can over run the fuel pressure regulator and make your car run rich.
