Well that's not that bad. So I still technically redline at 5k or whatever it is with the b27?
Eta Reving to 7k??
Pull your lower cluster trim (the flat piece with the thumbscrews in the back) and if you're lucky enough to have a late model cluster swapped in just snap a picture of the coding plug on the front. Jim's 99% likely to be correct but it's safe insurance to make sure its not an i injection setup with a b27 head. Though it's most likely nothing more than someone replacing a cluster with a junkyard find to fix a busted gauge.
Edit: i see you mentioned stock dme, but you didnt mention what dme it was, that could also rule it out pretty fast1990 332i, 4 door
2008 KTM 990 Superduke
2018 Golf R, 6spd manual (Pending delivery)
2017 Mazda CX-5 GT
2007 Z4M Coupe - Sold to very nice peopleComment
