m20 24lb Injectors?!
  • bimmerboy709
    • Oct 2012
    • 100
    I hear they are BARELY adequate for your average stock m20 at 14lbs if i'm not mistaken.
    I say to hell with that!
    Where do I start my search for some 24lb injectors for my m20b25?
    Thanks !
    ERHMAGHERD! BERMER!
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    Dude 17 or 19Lb injectors or more than enogh for most modded m20s unless you have a turbo or 3 liter stoker your not going to need any more than that
    88 325is Five Speed
    Lachssilber
    • bimmerboy709
      • Oct 2012
      • 100
      True. I'm jumping ahead of myself. I envisioned the e34 afm conversion with a dinan chip.
      I guess its to the 19lb e34 injectors for now then.
      ERHMAGHERD! BERMER!
      • Cronopoulos
        • Jul 2011
        • 2187
        Also, ford 19lb injectors are also easy and inexpensive to source.
        Project log -- DIRTY 30
        2.7i * Megasquirt tuned * E85 powered
        • bimmerboy709
          • Oct 2012
          • 100
          I can find 19lb injectors off 5.0's right?
          ERHMAGHERD! BERMER!
          • Cronopoulos
            • Jul 2011
            • 2187
            I belive so, don't qoute me on it. I purchased my set via MaksV - http://www.r3vlimited.com/board/showthread.php?t=242072
            Top notch seller and i have put 10,000+ HARD miles/different fuels with 0 issues.
            • bimmerboy709
              • Oct 2012
              • 100
              Thanks a lot man. Gonna pick up the 19# Type 3 Ford injectors off of him :)
              ERHMAGHERD! BERMER!
                • 37832
                If your engine is completely stock (chip or not) you should put nothing more than 17lb M50 injectors in there. Otherwise it's going to be running rich for NO reason. Trust me, I've done this a time or two.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                  In my experience, unless there has been significant work done inside the engine to increase mass flow the OE 14lb injectors are more than adequate if they are clean and working properly. External mods (other than FI) don't significantly increase mass flow and don't count.
                  • dnguyen1963
                    • Nov 2011
                    • 2649
                    You should search this forum to see the many threads related to the use of 19# injectors and stock chip before plunging into this project. I can sum it up for you...rough idle, running rich, and no observable benefit.
                    • bimmerboy709
                      • Oct 2012
                      • 100
                      Thanks for the pointers everyone. I picked up some 19# injectors today off an e34 and im going to have them cleaned and wait to upgrade my afm to the bigger e34 afm before installing them. Does anyone know exactly what is needed for this mod? Im sure a bigger throttle body will be needed but is there anything else im missing?
                      ERHMAGHERD! BERMER!
                      • ROLLingKING
                        • Apr 2011
                        • 1169
                        take your time and research. Google searches will bring up a million ways of doing this. a stock ecu with bigger injestors wont do anything. u can start collecting the parts and throw em when u have the complimentary parts but read and youll find it already out there
                        m20 is plenty. im simply a drifter.
                        build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
