fuel pressure regulator
  • inferno27468
    • Aug 2011
    • 66
    can i use the fuel pressure regulator from an 86-87 buick with the part number 0-280-160-233? i heard the psi ranges from 3-5bar not sure if this is correct. but i am having fuel issues cause i do have it chipped and have a 255 tre fuel pump with the secondary fuel pump deleted. 19lb injectors. i have a universal adjustiable one but it sucks nuts soo i was wondering if this would work. also because when ever i accelerate it sputters cause idk what psi to put it at cause it sounds like its shooting ducks lol. someone please help me out with this issue hoping to not spend alot cause im broke lol thanks in advance you guys always save the day aha!
  • 5Toes
    • 9836
    the autozone brand one is $50, use that
      Is you chip tuned for 19lb injectors? If so use the stock FPR. If not, put the OE (14lb) injectors back in and use the stock FPR.
        • 34835
        agreed. use the stock FPR.
        • inferno27468
          • Aug 2011
          • 66
          well i was hoping to keep it where its at i mean 50 is pretty cheap unless i snatch one from a junkyard but new is better lol and anycase i dont have the old injectors and i dont wanna go back to stock and yes the chip is tunned for them its jus my fuel pump is dumping alotof gas soo i need it to become equivalent lol i am gonna give autozone a call thanks guys
