My 2.7i lives!! And it sounds mean
  • M44schnell
    • Apr 2012
    • 123
    I just finished up work on my 2.7i build and i have to say im impressed, it sounds crazy lumpy from the cam but runs ok. Any thought on why it hold the revs so long after bliping it?
    Here it is let me know what you think, im just happy it runs again.
    Here is first real run:
    And after all the kinks worked out:
  • lcoleman
    • Jan 2009
    • 331
    That sounds great! Details, mainly what cam?
    • M44schnell
      • Apr 2012
      • 123
      The setup is a SETA bottom with a rebuilt head and a 288 shrick. Long tube eBay headers (more like mid-length), M30 MAF (is what I had) and a dinha tuned 173 ecu. Runs pretty damn good. But the stock 2.93 gears are not good with this setup, dosent come alive till about 3000 and by then your moving pretty quick.
      • M44schnell
        • Apr 2012
        • 123
        Edit got my number wrong its a 284, I had to look at the box again.
        • TG Goose
          • Jul 2011
          • 234
          it looks like it runs away from you when you blip the throttle tho
          ______________________________________
          1984 LSB 318i - Sold
          1986 325i - Motor Swapped Track Car Project
          1995 318ti - Sold
          1999 540iA - Daily Driver
          • Gary Horneck
            • May 2011
            • 435
            Very nice. Welcome to 2.7i land.
            2011 335i/1995 Mercedes C220 (rallyx)
            • M44schnell
              • Apr 2012
              • 123
              Yea, whats up with that?
              When you are on the road you cant really tell, but its running really doggy down low like it is running way to rich and docent rev quick as it should. When it dose rev out it really has the power but down low not so much. i know with that heavy a cam it wouldn't really run till up high but its just not running quite right.
              Any thoughts? No codes are coming up.
              other than that i can feel its gonna be a monster.
              • bpmack16
                • 1521
                Did u use a 885 head?
                • M44schnell
                  • Apr 2012
                  • 123
                  Yea, 885 head, new springs, seals, rockers. All new gaskets through out.
                  • redsubdivisions
                    • Feb 2011
                    • 1762
                    I shall be joining this club in due time. I can't wait to get my 2.7i in and then eventually turbo. Nice work, sir.
                    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                    2012 Passat TDI - DD Duty
                    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                    • M44schnell
                      • Apr 2012
                      • 123
                      The only real problem i have is that i need waaaaaaaaaaaaay shorter gears, the 2.93lsd docent match the power-band of this setup at all IMO. Other than that im pretty happy with the outcome.
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        I have a 4.10 LSD for sale if you're interested.
                        • 1fastm50
                          • Aug 2009
                          • 342
                          So if you blip the throttle at idle, it takes a while for the rpms to come back down? If so, check your throttle position switch. Of the 3 pins on it two have continuity when the throttle is closed. Its the middle one and one of the outer pins. If you dont loosen the two bolts on the sensor and turn it to see if youre able to.get continuity with the trottle closed. If not then the sensor is bad on the inside. The solder tends to crack but sometimes the switches are bad.
                          Racelands are cheap shit.
                          Originally posted by whodwho
                          So are r3v members
                          dude, this is R3v. there's like 40 project threads, and like 20 FS threads and 100 members ride threads of stupid shit. guaranteed laughs on every page. cut springs, rolled cars at 20mph, fishtank heater core, selling broken stuff, painting cars with paint brush, cheap wings, hella-flush and then there is Vlad, king of the eta M3
