If so Please tell me what brand turbo ?
Can i put a turbo on a stock 1989 325is
Tags: None
First, There is a forced induction section on this forum. If you do not know what FI is, then you shouldn't turbo.
Second, are you looking for ONLY a turbo, or a whole turbo setup for $1000?
Third, you can edit your posts if you mispell something.
Fourth, do some research on your question in your OP.
Fifth, if you do not know what OP is, then you have no hope.Comment
The cheapest way to turbo your car is to just bolt the turbo manifold on to the back of your exhaust pipe. Run some other kind of pipe (PVC would be fine) off of it back under your car to your air filter. Don't waste your money on a CAI just find a way to connect the PVC pipe to your stock air box. You should be looking at somewhere around 50-80hp depending on the size of the turbo. Make sure to post pics of your build in the project forum!What it feels like owning an e30:
88 325 S50 swap in progress
90 325ix
