As a last ditch effort, I come to thee, fellow Bimmerheads, in hopes of solving this conundrum.
It all started when I swapped out all the belts and water pump last September. I wasn't able to bleed the system easily because the bleeder screw was stripped so that was a headache. I eventually got it running at an optimal temperature and took it to H20i last year with no problems.
That was over a year ago and I've only put 6k on the car since. I started having issues with starting and traced it to the alternator so that was quickly replaced, and upon pulling up to my friend's garage to do so...my bypass hose blew and spilled like a skunt. I noticed I would occasionally have creeping temps at idle over the previous months so I had begun questioning the thermostat.
I tried swapping the old one out but the bolts holding the cover of the thermostat housing snapped so I ordered a new housing. I also replaced the bypass hose, THREE TIMES! The first one was too long and hit the mechanical fan, so I cut it only to find it leaked. The second one came in already ripped. The third was fine, and then a tiny pin sized hole blew out of the top of my new thermostat housing. Careful use of JB Weld took care of that and this is where I stand:
The car, no matter how much I try to bleed out the coolant system, still overheats. The head gasket doesn't seem to be blown, the thermostat is new, hoses are good, radiator was fine and got cleaned out when I did the water pump, and I am bleeding it properly. I never let it get too hot to the point where I'd imagine the head gasket would blow but I am stumped.
I just realized my electrical fan, the one behind the grille, isn't spinning. I don't know if this could cause my disastrous dilemma but I am drawing blanks at this point. The radiator fan spins properly and the top hose is hot and allows coolant to flow. I am getting a ton of steam coming through the bleeder but I realized fuse #19 (7.5amps) was blown. I figured that'd kick the fan back on but it's still not spinning after replacing it. I also noticed, upon removing the grille, that I could pull the fan off. I'd imagine it's supposed to be held in place by hardware, amirite?? This fan won't kick on when I push in the AC snowflake, which I read will usually do the trick.
Also: the heat isn't kicking on. Hasn't consistently in a while.
WHAT COULD IT BE?!?!
