pulling m20 engine, remove gear selcetor on tranny?
  • ahalfacre5
    • Aug 2012
    • 156
    just like the title says, I pulled my 87 m20 for a lower mileage 88 m20. im putting the tranny on the new engine and dropping it in today. should I disconnect the gear selector from the transmission... it looks like it would be a bitch to put back on
    1986 325es
  • e30 gangsta
    • 3877
    You should be able to pull it and drop it in, with the lever installed.
    • ahalfacre5
      • Aug 2012
      • 156
      spank you
      1986 325es
        You can do it that way, but I think it easier to install the engine/transmission with the shifter disconnected and still in the car and re-connect it after. With the engine sitting on the motor mounts, the transmission cross member off, and the drive shaft still disconnected, it is pretty easy to re-connect the shifter. The inverse of that applies to removing the engine/transmission.
          • 37833
          Agreed, I always install the shifter assembly after the engine/trans are in.
          Grover Beach, California
          BimmerHeads.com
