What is this plug?
  • downforce22
    • Aug 2009
    • 3192
    What is this plug?
    I recently swapped from motronic 1.0 to 1.3 and got the car running. This is still unplugged, what does it go to?
    Right now it is just dangling in my glove compartment and my obc seems to work with it still unplugged. Picture taken from strictlyeta.net.
  • downforce22
    • Aug 2009
    • 3192
    anybody?
    • VAE30FTW
      • Jun 2011
      • 171
      ABS ECU plug
      H&R OE Sport Springs - Bilstein HD's - Kosei K1's ET27 - Toyo R888 - ZHP 5spd knob - BavAuto strut bar - DINAN Chip - E30 M3 Offset Bushings - Colgan bra - P-car daily
      • downforce22
        • Aug 2009
        • 3192
        what makes you say that?
        • downforce22
          • Aug 2009
          • 3192
          anyone?
          • vpilarrt
            • Jun 2006
            • 2096
            Pretty sure they're C131 and C136.
            C131 is used if you have an automatic transmission, not used for manual.
            C136 is tied to the AC circuit.
            Both feed the the ECU to change idle speed appropriately.
            • downforce22
              • Aug 2009
              • 3192
              Thanks that sounds right.
              'C131 is the Park/Neutral signal to the ECU pin 42 - engine should not start if this is bad or not connected
              and C136 is for the A/C as BMW BUM suggested - it tells the ECU to run the engine differently when the condenser is on.'
