Coolant leak from head? urgent, wrong section, I know
    I would have to say that the head gasket is leaking in two spots. The chances of curing it without removal of the head and a surfacing cut are slim to none. And while the head is off you might as well do the valves and valve seals.
    The small opening between the intake ports is the oil return passage. Be sure to use new seals on the oil return tube when the intake is reinstalled. The VR head gasket kit will have most of what you need, other than the head bolts. Use a BMW or Goetz head gasket.
    • Andy348
      • Sep 2009
      • 688
      Damn. Sounds like I've got some research to do.
      I've messaged the PO of the engine to see if he actually rebuilt the engine or not. Presuming that he did, what would the valves/valve seals cost to do, along with a resurfacing of the head? I'm just praying its not cracked at all.
      • Kozworth
        • May 2011
        • 1339
        isnt the second pic a so called "pcv" from the crankcase to the intake mani, and the head has the pcv hose from the valve cover to the intake mani. I could be wrong, but I was in the same position and wondered what it was, thats all I could think of.
        • sweet6e30
          • Feb 2011
          • 531
          Oh sh!t Andy!!!!:(
          pull the head and rebuild
          head pressure test and resurface if not cracked
          valve job
          head gasket ++++KIT++++ Reinz
          head bolts
          bitch tube O rings
          timing belt & tensioner
          w pump
          T stat housing
          hoses
          my build here ---> http://www.r3vlimited.com/board/show...ht=lemans+blue
          • Andy348
            • Sep 2009
            • 688
            That's what I figured. Lucky enough I've already got a practically new timing belt, tensioner, water pump, t stat housing, t stat, coolant hoses, etc.
            John do you know any good machine shops in the west island or anywhere really in Montreal?
            Thanks all for the help btw, I'd be nowhere without this community
            • jeffnhiscars
              • Jun 2011
              • 6010
              Umm... a "practically new" timing belt is the same as an old one. They are $12 without the tensioner.
              Alice the Time Capsule
