Won't start after 17# injector swap. HELP!
  • 95///M3
    • Mar 2005
    • 181
    1989 325is. Ran well, swapped out stock injectors for 17# M50 injectors yesterday. Also replaced both coolant sensors that the injector harness plugs into.
    Cranked, turns over, no start. Sprayed ether, it starts. Swapped back in stock injectors no start. Swapped to a different DME, still no start.
    Pulled both fuel lines, fuel is pumping as it should.
    Checked and double checked, fuses, injector harness pins are seated and plugged into engine harness.
    Stumped, what next?!
    Thanks,
    Jim H.
  • Jahman093
    • Sep 2012
    • 183
    Are you getting fuel? Spark?
    • 95///M3
      • Mar 2005
      • 181
      When I spray ether, it will start, indicating spark.
      I am getting fuel to the rail, but haven't confirmed if they injectors are actually firing. My hypothesis is that they are NOT pulsing, will confirm with a noid tester tomorrow.
      • lcoleman
        • Jan 2009
        • 331
        Feed/return lines get mixed up?
          Check C191 (underneath the intake).
          • 95///M3
            • Mar 2005
            • 181
            Only removed them to check for flow after the no start condition started.
            So, no.
            • 95///M3
              • Mar 2005
              • 181
              I have checked for proper seating of C191 to injector harness several times. Is there a test procedure to probe pins?
              • Balleristic31
                • Aug 2009
                • 4198
                Are the coolant sensors hooked up correctly? (Not reversed?)
                -NICK
                • 95///M3
                  • Mar 2005
                  • 181
                  Checked. Also swapped out sensors for known good sensors in the E30 that is parked beside it in the garage....
                  • Varinn
                    • 780
                    I had this EXACT problem earlier this summer on my 325i. The car was running well and had all sorts of new parts so I swapped in a set of 17# injectors (rebuilt) and drove to work, after the work it refused to start and I found a massively leaking FPR o-ring I replaced the seal and the problem remained.
                    I swapped back in the noisy stock injectors and it still wouldn't start, checked fuel, spark etc and found nothing wrong. Back to the 17#, still no start and one day I put in the original injectors one more time except I swapped out a couple of them with some other stock spares and the car fired up immediately and ran perfect.
                    In the process of troubleshooting (and a ton of tune-up items I figured I may as well do while I was solving this) I replaced these parts with new oem:
                    CPS
                    Coolant temp sensor
                    FPR
                    Fuel Pump
                    Fuel Filter
                    All fuel lines
                    Cap
                    Rotor
                    Wires
                    Plugs
                    Main relay
                    Fuel pump relay
                    Before replacing parts I had cleaned the fuel injection connectors and tried a spare DME, CPS, relay, etc. My car already had all new vacuum hoses from when I installed the motor recently, and the compression tested out perfectly on all cylinders.
                    You're on the right track, grab a noid light (or stethoscope) and figure out if your injectors are firing or not before throwing parts into the car. In the end the only obvious issues I was able to find was that the injectors seemed to fire at odd times sometimes with 2 or 3 shots and random gaps between when they'd work again. I'm not sure why the problem remained after swapping my stock injectors back in the first time after it showed up, but in the end the stock ones seemed to be the fix.
                    1990 332i, 4 door
                    2008 KTM 990 Superduke
                    2018 Golf R, 6spd manual (Pending delivery)
                    2017 Mazda CX-5 GT
                    2007 Z4M Coupe - Sold to very nice people
                    • 95///M3
                      • Mar 2005
                      • 181
                      CPS
                      Coolant temp sensor
                      FPR
                      Fuel Pump
                      Fuel Filter
                      All fuel lines
                      Cap
                      Rotor
                      Wires
                      Plugs
                      Main relay
                      Fuel pump relay
                      Noid light is here today.
                      Will post an update after I test to see that the injectors are pulsing or not.
                      Ironically I replaced a set of stock injectors on my other e30 at the same time an that car runs beautifully. Maybe I'll try to swap this into this car....
                      Jim H
                      • tim88325is
                        • Jul 2008
                        • 201
                        Pull back the rubber boots on the connector to check for damage or corrosion on the back of the pins.
                        The C191 connectors can be a real weak point on the cars at this point...
                        • Quinthirty
                          • Mar 2012
                          • 318
                          I'm curious about your solution. I changed mine to M50 injectors today as the chip was also changed to 24hp Ebay chip. The car is not firing well, won't idle, smoking, and is very rough. It was ok when the injectors were stock and chipped.
                          • amcink
                            • 788
                            Subscribed. I'm seriously considering upgrading to M50 injectors but need more insights. I have a 325e
                            • bernzpeed
                              • 3917
                              I installed 17# injectors on mine and an ebay chip and it runs like a champ.
                              89 E30 S52
                              Transaction Feedback.
