Right now this motor has 2 modes of operation:
1: runs as normally as a 300k motor can
2: runs so filthy rich that it won't even idle unless I unplug the AFM.
I'm kind of stumped on this one. At first I thought it was a vacuum leak but the elbow, hoses, usual suspects look ok. So I replaced the intake manifold gasket, valve cover gasket, vent tube seals. no change. In retrospect the intermittant nature of this should have warned me it's probably not mechanical. next?
-New coolant temp sensor
-tried spare AFM
-tried spare ECU
-O2 is unplugged
-tried without TPS
-tried without cold start injector
every time, car will come up, idle great in the driveway.. as soon as I go around the block it goes into asshole mode about halfway through, limp it back home with my foot 1/3 way down on throttle just to keep it from stalling.
When it's in this mode, idling with the AFM unplugged, I started probing around, wiggling wires, etc. Can't seem to find the culprit. AFM connector has 5V just fine. If I plug AFM in the car just immediately dies.
Any ideas??
-tried spare AFM
-tried spare ECU
-O2 is unplugged
-tried without TPS
Any ideas??
