air pump question
  • harold30
    • Jul 2011
    • 180
    air pump question
    hi guys,
    i would like to ask if removing the air pump will create a performance issue. please refer to this link: http://bmwfans.info/parts/catalog/E3...ontrol_engine/
    thanks in advance.
  • FLG
    • Sep 2011
    • 3165
    Give us some info what are you trying to do?
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • harold30
      • Jul 2011
      • 180
      Will remove the air pump and put a straight hose instead. Would it be okay if I do that?
      The intake boot I will use will hold the ICV only and no arm for air pump.
      What do you think?
      • harold30
        • Jul 2011
        • 180
        anyone?
          • 37833
          I don't know why they call it an air pump but yes you can remove that. Just make sure you have a check valve in the line from throttle body to brake booster and you're fine.
          Grover Beach, California
          BimmerHeads.com
          • harold30
            • Jul 2011
            • 180
            Great. thanks!
            • TobyB
              • 5287
              air pump
              wow- never woulda thought it woulda been called that.
              Nope- lotsa cars didn't have that. I replaced mine with a tube and a hose
              and it seems to have no problems with braking.
              Air pumps USUALLY look more like this.
              t
