***12/2/2012 Issue has been resolved see last post***
I have a bogging down issue when the car will be sluggish even with the gas fully depressed then after about 5 seconds start running again. I have changed the following parts:
Plugs, Wires, Cap, Rotor, Fuel Pressure Regulator, rebuilt AFM.
What's driving me most crazy is all the things that I've replaced have been tested to be out of specification but still aren't solving the original symptoms of severe sluggish behavior from 2000-3000RPMS. The engine revs but the car doesn't move.
I'm down to replacing the Coolant Temp sensor because that's the last item on the list that might cause symptoms like this along with a slight cold startup erratic idle (maybe 100RPMS)
If it helps brainstorm ideas I've also have the clutch replaced about a year ago with a new Sachs one including all the seals, pilot bearing, throwout bearing the whole nine yards.
Would love some ideas of what to test next beyond these things. Throttle position sensor, fuel pressure et all? I've got electrical testing equipment but not fuel and it's a 40 minute drive to "rent" one from a parts store.
In exchange photo of sad children that want to drive in car in question (on the right, the rusty one)
