I've got this problem that keeps rearing it's ugly head - 1986 325es
Symptom: Driving on the highway, I'll lose power when going up an incline hill trying to maintain 70. It'll start bucking, but if I let off the gas it'll start running ok, albeit with less power and it slows down. On a decline I get power again. It's almost like if I keep pressing down on the gas it is flooding?
Other symptom - Then starting out from a dead stop, it'll sort of lose power, semi stall, then pick right up with a surge.
I've fiddled with the MAF, and the semi-stalling from stop issue would get less pronounced if I opened up (counter clockwise) the air bypass screw on the MAF.
Then if I move the needle (un-doing the screw that holds the arm on the MAF) and position it further up the track, things smooth out. An unmodified MAF runs like crap.
Idle is fine.
New plugs, new injectors (flow-matched), rebuilt engine, new cap and rotor, new CPS and speed sensors, new O2, new temperature sensors, new fuel pump, new fuel filter, no rust in tank.
Only thing I could think of is a failing fuel pressure regulator?
Idle is fine.
