open loop idle and temp issues
  • Earendil
    • 1662
    #31
    Originally posted by jlevie
    There are lots of places to have an intake leak where carb cleaner, or the like, won't work. The only way to check for intake leaks is to have a shop run a smoke test.
    At this point jlevie, I think I can confidently say that if you wrote yourself a script that just searched the board for new posts that mentioned carb cleaner and auto reply with the above line, that'd you'd save yourself 4-6 hours a week :D
    1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
    2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
    I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
    • Gregs///M
      • Mar 2012
      • 2459
      #32
      Since you can replicate an irregular temp reading by jiggling the rear cluster connector, it is safe to assume the cluster main board has cracks in some solder joints, which is a very common electrical issue on all E30s.
      It will require reflow of solder.
      Installation of a after market temp gauge is recomended even if temporary or use of an IR thermometer.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
      • uuc328
        • Dec 2012
        • 85
        #33
        now that i know temp is stable at this point the idle is my primary focus. would a vac leak cause RPMs go to up and down? I would think it would simply show itself as a high but stable idle.
        i like the idea of a secondary temp gauge, any suggestions?
          #34
          Even better would be people searching first and starting a thread with, "I just had a smoke test and fixed the leaks it found, but the engine is still...".
          • dnguyen1963
            • Nov 2011
            • 2649
            #35
            ^^^ I think that this should be a requirement for joining this forum.
            • uuc328
              • Dec 2012
              • 85
              #36
              finally got this sorted, ended up being the small 2 prong temp sensor after all. I think it was only used on the early cars. 12631279722
              eta is happy again :D
