Stroker questions...
  • CrJdMc
    • Feb 2012
    • 195
    So i have been researching a this topic for a while. And When spare money comes up, I am wanting to build a stroker m20. I have heard that i can use a m20b25 block, and get a 2.7 crank and then I rods and I pistons (shaved 3mm) as well, and that will put me at around a 2.8L? Anyone else have any info on this topic? i know I.E makes kits for this, but i am on a budget.
    sigpicInstagram: bir_madhatter
    Add me on Facebook: https://www.facebook.com/connor.mcco...57?ref=tn_tnmn
  • digger
    • Nov 2005
    • 6160
    i dont think anyone has really tried to build a stroker M20 before
    • Simple_Smith
      • Aug 2011
      • 585
      this
      1989 JDM-Tech 2
      2010 335 D for daily
      • ak-
        • 12422
        those are some big dreams OP
        1991 325iS turbo
          • 37833
          So you want to use a 2.7L crank and not increase the bore yet expect it to be a 2.8L?
          My advice is do some research on the subject. If your car is already a M20B25 I'd leave it as is. If it's a M20B27 car I recommend keeping the bottom end as-is and swapping to a M20B25 head, intake, and all electronics/sensors/etc.
          Grover Beach, California
          BimmerHeads.com
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            Stock eta bottom end with i head and other stuff is not worth the trouble. Seta ftw. Make a true 2.7i and actually get one up on an i car. I had a "budjet" 2.7 with a g260 and s4.10 and could not catch my buddys chipped eta g260 3.73 combo. I was so disappointed after the build.
            -Andy
            • Saascat1
              • Jan 2013
              • 60
              You can use the a 2.7 crank in a 2.5 M20, after all, 2.3 is a stroked 2.0L, the same as a 2.7 is a stroked 2.5L. The bore is same in each respective motor, as well as the rod length, the crank is the difference.
              Shaving the pistons would increase capacity but would reduce compression and therefore rob you of any potential gain. If you want more capacity with a still relatively small stroke, you bore out 1mm oversize a make a gain that way.
              IMHO the key to seeing horsepower gains would be the 885 casting head, and using oversize valves to allow the whole engine to breathe better. A mild cam will wonders as well. I am running a 276/284 degree cam in my E34 525i and it boogies from 3000rpm.
              If you want some straight honest answers to any of this, call Jeremy at I.E. The man is a Guru on all things engine-wise.
              • frankenbeemer
                • Sep 2009
                • 2260
                Here is some stuff to get you started.
                Don't buy an e30
                They're stupid
                1989 325is Raged on then sold.
                1988 325 SETA 2DR Beaten to death, then parted.
                1988 325 SETA 4DR Parted.
                1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                • acolella76
                  • 2950
                  Uh I had the stock eta bottom end with an 885 head and a cam. And I was hanging with M50 swapped E30s. So it is kind of worth it IMO...
                  -Alex
                  • MonkeyMan
                    • Jul 2011
                    • 426
                    nope, 130mm eta vs 135mm i
                    After countless hours of researching various M20 motor builds, I think it's safe to say that you get what you pay for. When guys say they're 'on a budget', in most cases it means custom pistons are out of the question. This is a huge limiting factor when it comes to actual gains. There are only so many combinations you can toss together utilizing stock pistons, and at that you're most likely gonna sacrifice compression ratio and rod length for increased displacement unless you start machining valve reliefs (for a higher lift cam) and piston skirts (for a stroke > 84mm).
                    I've tried to think of ways to beat the system when it comes to using stock pistons, but I keep coming to the conclusion that if I'm going to build it at all, I might as well build it right. It may take more money (think 1k for custom pistons and 1k for machining) and possibly more time, but in the end I know I'll be happier with the results.
                    You can always skip the stroker build altogether and try to maximize your stock displacement by refreshing the engine, adding a slightly more aggressive cam (like a Schrick 272), MAF conversion, chip, and a free flow exhaust. You might be surprised and it will probably run a lot better than a lot of 'mickey mouse' strokers out there.
                    my .02
                    Make the bastard chase you.
                    • CrJdMc
                      • Feb 2012
                      • 195
                      Thanks a lot guys! ill be reading up a lot, and if i have any more questions ill just post here!
                      • Simple_Smith
                        • Aug 2011
                        • 585
                        1989 JDM-Tech 2
