1986 325es - stock.
I thought the car was only not starting when it rained...I could crank it for ages and it would eventually start. I replaced the cap and things were fine.
Now fast forward two weeks and the car just cranks and cranks. It will get to the point where it starts to catch, but won't start.
I got angry, hooked up some jumper cables and kept cranking until the car finally started. It idles great. If I rev it, it will nearly stall at lower rpms, but smooth out past 2k. If I drive it, it will intermittently bog down or stall out when first starting out. If I rev it up, I can get it to move fine.
There are occasional misses throughout the rpm band. If I try to restart within 3-5 minutes it will fire right up. If it sits longer, it will crank forever before starting. Overnight, it will likely kill the battery before starting if I keep cranking.
Smoke test revealed a minor leak at the fpr hookup. Replaced the hose and we're good there.
All Bentley tests check out sans fuel pressure since I dont have a guage.
My guess is in tank pump isnt all there any more. Jumpering the fuel pump relay has both pumps on but something is still not right.
Any takers? I have to go out of town for work and would rather take the e30.
As always, thanks in advance.
