could be your rotor button is on backward :)
Engine sounds?
After I got my valves adjusted my car started making a similar noise. it's loud as dump.
guy at the shop said after he put everything together, fired it up and heard that noise, he went back in to check the valve clearances and just go over his work. Second time- still noisy- several thousand miles later- car's as healthy as ever. Shit is loud, though./______\_o_/______\
l{(OO)=[//][\\]=(OO)}|
\ #___======___# /
|__/-------------\__|
"Took me an hour to do this..."
took me like three seconds to copy/paste it- FOR SCIENCE!!
Barney Fucking RubbleComment
Mine made the same sound after a Timing belt job, the alternator belt was to tight and those old bearings were screaming. i just backed it off a little.sigpic
Reich und Roll!Comment
I'm not the OP, but I resolved the sound mine was making which (given bad recording audio) sounded like his. My water pump bearings were shot, even though it is only a year old and maybe 10K miles. I did as suggested here and pulled off the alternator belt, which produced a very quiet engine. After removing the water pump and giving it a spin, it sounded like a pepper grinder! The new one is whisper silent when spun :up:-------------------------------------------------
1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!Comment
I figured it is the water pump, I just replaced it and had a bit of trouble torquing one of the bolts down. I will order a new one and rip it down again.. for the third time. Wont be for awhile I will let you know my results.I'm not the OP, but I resolved the sound mine was making which (given bad recording audio) sounded like his. My water pump bearings were shot, even though it is only a year old and maybe 10K miles. I did as suggested here and pulled off the alternator belt, which produced a very quiet engine. After removing the water pump and giving it a spin, it sounded like a pepper grinder! The new one is whisper silent when spun :up:Comment
