Not running on all cylinders
  • Maad325
    • Jan 2013
    • 132
    I have an 87 325E that I bought off craigslist as a project and its been sat for close to 7 years. It runs but cylinder number 5 isn't running, it's getting spark but it doesn't run. Any ideas?
  • dnguyen1963
    • Nov 2011
    • 2651
    To run it must have air, fuel, and spark. Check your fuel injector going into cyl 5 then check the compression number for that cylinder.
    • Maad325
      • Jan 2013
      • 132
      The compression on cylinder 5 is good, I'm think the injector is suspect. I was running it and I couldn't feel it ticking when it was running, the leads to the injector have continuity and I measured 6 ohms off the injector itself.
      • Myster-E
        Performance
        • 552
        Pull the valve cover to check and see if the one of the #5 rockers are broken.
        1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
        Visit www.BimmerHeads.com for all of your 12 valve needs!
        • Maad325
          • Jan 2013
          • 132
          Not a bad idea, I'll check tomorrow when I have sun light and when it isn't raining.
            • 37832
            Definitely could also be a clogged injector from sitting.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
