bad water pump ?
  • e30wavee
    • Jun 2012
    • 36
    bad water pump ?
    i put fluid but no flow runing though the motor what can cause this ? in need of help someone plz help !!!
  • dnguyen1963
    • Nov 2011
    • 2649
    We need more information than this to help you out...describe the situation a bit more please.
    • E30_fiend
      • Apr 2006
      • 7348
      With the vague information given, Im guessing that your thermostat is stuck closed. Replace it and you should be good to go.
      Taylor
      • e30wavee
        • Jun 2012
        • 36
        i put water instead of anti fluid and over night it turned to ice so i did my best geting all the the ice out of the hoses i went to bmw got the anti fluid mixed it with water and put it in to the engine it went down the res tank all hoses are warm except the lower radiator hoes im not sure if its a thermostat or water pump
        • bmw325csi
          • May 2007
          • 4045
          thermostat.
          harry/harout
          • vpilarrt
            • Jun 2006
            • 2096
            Thermostat could be frozen shut. Water pumps don't fail by not pumping water - their bearing and/or seal fails and then leaks around the shaft.
            • e30wavee
              • Jun 2012
              • 36
              i was thinking maybe the water pump froze so when i turned the car on the bearing got shot
