over heating problem!! help
  • e30wavee
    • Jun 2012
    • 36
    BIG problem on my hands my 325i wont stop overheating i changed the radiator the water pump thermostat,all the hoses seem to get hot except for the bottem radiator hose car wont stop overheating i bleed the system that didnt work im stuck here with a >?
  • TG Goose
    • Jul 2011
    • 234
    Bleed it again. If that doesnt work, do a cooling system pressure test and do a chemical test to see if you are getting exhaust in the cooling system.
    ______________________________________
    1984 LSB 318i - Sold
    1986 325i - Motor Swapped Track Car Project
    1995 318ti - Sold
    1999 540iA - Daily Driver
    • dnguyen1963
      • Nov 2011
      • 2651
      Search for Jlevie's bleeding procedure then follow it to the letter.
      • K1CKBAC
        • 306
        My problem after numerous attempts at bleeding the crap out of the car was a bad temp gauge.
        My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
        • jeffnhiscars
          • Jun 2011
          • 6011
          Do you have the plastic shroud on your radiator ?
          Alice the Time Capsule
          • e30wavee
            • Jun 2012
            • 36
            Yes I do
            • jeffnhiscars
              • Jun 2011
              • 6011
              Originally posted by e30wavee
              Yes I do
              I had to ask since I spent 2 years changing water pumps, tstats and fan clutches til I realized the car had no shroud :(
