Oil level sensor - How to replace molded plug
  • Just Scott
    • Dec 2010
    • 140
    The male plug of my oil level sensor completely disintegrated.
    So I pulled one out of a junkyard car and it did exactly the same thing. Every time I touched it to clean it up before installing, more pieces of the plug fell off. It is now pretty much useless too.
    Options I see:
    1. Its a molded plug, so I don't see replacing it with a stock piece. Some say you can find them from Mouser, but not when I contacted them.
    2. The replacement part is at least $122 from BMS - which is crazy.
    3. Another option is to cut the plug and harness and wire in an aftermarket weatherpack or similar connector.
    4. Or I could just jam the male wires into the plug and wrap the thing with electrical tape.
    What do you think?
    1990 325is - sterling silver, very nice, maybe for sale
  • Mr. Burns
    • Aug 2011
    • 3516
    what do you mean disintegrated?
    they parts can be brittle, are you sure you're removing the plug properly?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • AndrewBird
      The Mad Scientist
      • 11898
      Get the part number from here:
      http://www.realoem.com/bmw/showparts...12&hg=12&fg=31
      And order one from the dealer. Should be #3 I believe.
      • Just Scott
        • Dec 2010
        • 140
        Definitely removing the plug correctly
        The plugs apparently get brittle with age. The one in my car now had nothing left, just the pins hanging out of the harness side connector.
        I'll look into that part posted, gotta have the 3-pin male side to work.
        Thanks
        • Just Scott
          • Dec 2010
          • 140
          Found this on EFI express for $12.50 plus shipping.
          If you are careful, you won't need to use the crimps. Carefully break the old plug apart with a pair of pliers or something and reuse the crimps after you bend the lock tabs up a bit.
          Winner, winner, chicken dinner
          • Just Scott
            • Dec 2010
            • 140
            Received and installed this plug tonight in about 20 minutes.
            The steps are pretty easy
            1. Finish removing the old molded plug from the wire ends - leave the factory crimps in place
            2. Pull off old boot
            3. Lubricate the inside of the boot with some dish soap and insert a tube - I used a bic pen body
            4. Thread the wire end into the tube and slide the boot on
            5. Slide the wire seals over the factory crimp connectors
            6. Make sure the crimp connector lock tabs are pushed out
            7. Orient the wires in the correct order
            8. Push the wires into the new housing until they click
            9. Push the wire seals up into the new plug
            10. Push the new boot up onto the plug
            11. smile....
            • wojtek79
              • Jan 2009
              • 46
              I must have removed close to 50+ oil pans since I have been dealing with BMW's and have never had that happen to me.
              • Just Scott
                • Dec 2010
                • 140
                All three in my possession are like this. Parts car, daily driver and the junkyard part.
                Must be a southern thing.
                • benyen soljax
                  • Mar 2012
                  • 290
                  This is a lifesaver! My 22 year old electrical connectors disintegrate when you look at them, and then I looked at the price of a new sensor :shock:
                  I will be taking this rebuild boot and doing it myself thanks.
                  Project 325is
                  Transaction Feedback
                  • Jdesign
                    • Jun 2012
                    • 198
                    I just did the pan gasket on mine, same thing, crumbled to bits! Glad to know I don't need a whole new sensor!
                    • benyen soljax
                      • Mar 2012
                      • 290
                      does anyone know what the wire colors were for each pin on the sensor side? My connector fell apart before i could see which wire was for which pin :(
                      Project 325is
                      • fitswell
                        • Nov 2008
                        • 224
                        hope this helps someone
                        01.5 S4 Avant - Sold
                        88 325iS - In pieces
                        91 e34 - Totaled by some dumbass
                        90 325i - Daily
                        06 e91 - Sold
                        feedback thread
                        • fitswell
                          • Nov 2008
                          • 224
                          Last night I found the sensor side male connector had disintegrated on my late model. Although this connector is used at TPS and near the diagnostic plug, neither of those make good candidates for a transplant. Now the sensor is $250 - ouch!
                          90 325i - Daily
                          06 e91 - Sold
                          feedback thread
                          • shawshankNG
                            • Nov 2020
                            • 142
                            This is the female part.
                            The male part is being a pain in the ass to find.
                            Mine broke too. Click image for larger version
                            1990 325iS
                            1990 318iS (sold)
                            • shawshankNG
                              • Nov 2020
                              • 142
                              Wild that 7 years later, the price is still the same on the same website. I've traipsed all over the internet looking for the connector but I just had to Google search EFI Express and voila
                              https://shop.efiexpress.com/products..._connector_kit
                              I'll see what I can get done tomorrow with any same connector from any part of the wiring harness. Else, I'll have to order and wait.
                              1990 325iS
                              1990 318iS (sold)
